A FPS (frames per second) above 60 will give you a very good result. Your monitor may only refresh at that rate. FPS can vary between Photofields and 3d (computer generated) fields. Most recent desktops with a $100 graphics cards can render very acceptable results. As with anything, the more you spend, the better you get (to a point).
