Hi Chris
It depends on the exhaust temperature of the 160-180 turbine. If the exhaust pipe temperature is over 700c such as the new JetCat 180 that has much higher exhaust temperature then you should give Tam a call and order his pipe. If you are using just a 160 size Tyrone like 160Sx or Rhino then you are fine with the stock pipe.
Mike
