RCU Forums - View Single Post - Help Setting Fixed End Points with Jeti
Old 05-08-2014 | 03:38 AM
shepga
I found the information I needed on another RCU thread. The key thing the Jet instructions don't tell you or at least I didn't see is that you first plug the Jeti box into the throttle port of your receiver and read the high low impulse values. You then use these values to set the controller initiation and high/low fixed endpoints.......easy enough. My controller is set up right now the way I like it. I initiate at full low stick and the prop starts turning when I advance the throttle 1 click.
