Originally Posted by
LGM Graphix
Really? How many different ways do you expect there would be to make an airtrap? This is the same basic design as their all aluminum ones from JMP but with a clear canister so you can see the fuel. Licensed...... unreal.....
Basic design, yeah right, all the traps before this were poofy bottles that flexed. BVM, Hansen,King Tech trap follow the same design. GBR came out with the first hardened fiberglass trap and clearly this new JMP trap is based on the GBR Traps.
But copying is no issue for you, and what a coincidence considering your copied the JMP firebird when you contracted Fly Eagle Jet to make your ill-fated liberty Jet.
The air traps will probably be fine, but GBR made them first.
