RCU Forums - View Single Post - Which is best angle for velocity stack?
Old 05-08-2014 | 09:18 PM
Flyfast1
Originally Posted by Rodney
This is contrary to most experimental results done by many. Is your engine and port inside a cowl? If so that may explain it as the airflow beneath a cowl can certainly change how things work. If out in the breeze have you tried other positions, you may get an improvement if you do.
Hi Rodney,
The engine is inside the cowl, but the velocity stack is outside the cowl. Without a velocity stack the opening of the carb is just slightly past the cowl, if that makes any sense. I can certainly turn the velocity stack around and try it with the cut facing rearward, so that the air is not forced into the opening.
-Ed B.
