RCU Forums - View Single Post - flip the motor on U can Do 3d 46
Old 10-04-2003 | 05:45 AM
EXCAP232
My Feedback: (12)
Default RE: flip the motor on U can Do 3d 46
Mounting the motor to the side would be preferred to the upright mount. It will also save the same problem of digging into the ground when you start flying inverted low passes. I have seen a few with this arrangement and it does work well even though it doesn't look as nice. You need right thrust to offset the tendencies of the plane going left. Most use 2 degrees (+/-).
EXCAP232
