RCU Forums - View Single Post - New Jet trailer
Old 05-11-2014 | 11:38 PM
  #61
Springbok Flyer's Avatar
Springbok Flyer
Default Here is my trailer
Hi guys,
This is my second RC model trailer. It is 3.6 meters long x 2.250 meters high x 1.9 meters wide. The door openings are 1.5 meters high and the height under floor is 280mm. Both floors are height adjustable and can slide out sideways. When the doors are open a shaded all round verandah can be had with two triangular canvas pieces added between the side and rear doors. The main frame construction is steel and everything else is aluminium. The power panel is dual 12v DC and 240v AC - powered by either a 125ah battery and 80watt solar system or external AC power - all used for either 12/24/240v charging up to 4x5amp load. The trailer has LED lights through out and a wireless reverse camera which can be viewed from my driver seat. The total weight is 850 kgs and has brakes fitted. Here are some photo's showing models and wings stored for transport. The front drawer is used for model stands, folding table, charger and other boxes. The rear quarter under floor areas are used for fire extinguisher, overnight marque and 40 litres of extra jet fuel. The front storage area is used for field fuel station, field tool box and other field requirements.
Hope you approve.
Cheers,
Jan
