A question about shafts.
i have been told that using a Teflon sleeve I will end up with trouble and perhaps a better option is to run the flex straight through the brass outer with a good lube.
so if I go with no Teflon sleeve do I need a smaller diameter brass outer and does the outer go into the front of the strut. At the moment the Teflon sleeve fits into the front of the strut perfect and the solid end of the inner flexi runs through a bearing in the back portion of the strut.
not sure what to do. Cheers
