Originally Posted by
madanna67
You will want a short piece of 11/32 brass tubing to go through the hull. Secure that in the hull. Then you will need the 5/16 brass tubing to run all the way through the strut and up through the 11/32 tube. That way if you need to you can replace the stuffing tube if need be. I will post a pic and some more detailed info on the brass tubes for you when I get home from work this afternoon.
Sweet got it now, some things take a little longer :-) the brass outer I have is one size too big, I'll get a length if 5/16 which will fit into the strut and some 11/32 for the stuffing box. I never grew up with imperial fractions so use to metric. Can you please confirm my rather rough slap up diagram, cheers
