Sam the Hurricane looks great, I live very close to Chad and I agree with you, if you need just about anything Chad is Awesome. Regarding your masking tape paint pull problem. Tamiya makes a very low stick masking tape which has proven to be gentle on underlying paint, when I used to build scale plastic models I used it to mask decals. Another option which might work is to use post it notes, I get the longer pads and overlap them, the trick with the post it notes is to use very little paint and lots of coats, to avoid the dreaded bleed under.
Love the Hurricane!
Cheers
