Hi Ross,
as far as I know, the yellow LED is for indicating the range check mode (blinking slow and in the end fast), Spektrum Analyzer active (blinking fast) and it also signals (continous for at least 3 min) the download of the speech file from the microSD-card to the module-board. While the speech file is transfered in the background, the DV4 can already send control information to the model. I did not test if binding also works during this stage. Maybe your "problem" is tied to that theme...
If nothing works, I would try to
- backup the DV4BTA settings with GC
- reset the DV4BTA in GC
- (re)flash the newest Firmware for DV4 (v2.63)
- flash the latest voice file (2.63, short or long version)
in the given order.
If all does not help, you maybe have to give it to WEA service or even better, contact Jens Ackermann from WEA first,
Is the module still reachable with GC in its current condition ?
best regards from germany
Thomas
