RCU Forums - View Single Post - Help with determining flying behavior
Old 05-12-2014 | 12:35 PM
mpieklik
Originally Posted by JohnBuckner
I certainly do heartily concur with Vertical Grimmace's suggestion and one step at a time is always what should be applied not only airframe changes but also this needs to be applied to learning to fly. Airmanship is always and for all of us a climb up an airmanship ladder and omit basic steps (rungs) then that will always come back to bite you in the butt latter. This is why most here and virtually all experienced flyers will suggest getting help from a mentor (instructor).
Sorry back to the airframe. In my opinion two things need to be accomplished before the next flight, You might call that step one:
Move that CG forward AND at least double your wing band count. Step 2 adding down thrust later only as needed.
John
Yes, I agree. Already planning to move CG forward and use 14 rubber bands. I'll see how it flies at half throttle and introduce down thrust from there if needed.
Again, appreciate everyone's help. I've found people at the club and online are generally willing to help. Just starting to wonder why I waited 25 years to get back into this hobby!
Matt
