RCU Forums - View Single Post - Need help with Cox .049 Cosmic Wind.
Old 05-13-2014 | 09:47 AM
Quorneng
Just a word of warning - don't use too much force trying to get the piston to move. Let the fuel dissolve the dried up oil.
The connecting rod is ball ended in the piston which is 'peened over' to hold it in place. Pull down on the connecting rod too hard and you run the risk of actually opening up the little end - then you might indeed find you need a new piston assembly!
