RCU Forums - View Single Post - ok next question is about servos buzzing
Old 05-16-2014 | 06:53 PM
JohnBuckner's Avatar
JohnBuckner
If what you have (you did not post the servo brand and model at least in this thread) are truly analog servos And they make a buzzing noise ar idle after you have completely disconnected the linkage by removing the output arm then you have something else going on, That is far from normal. What is very very common is to much drag in the linkage.
John
