Originally Posted by
R/C Ray
Thanks for the feedback. I have just about all the BUSA 1/4 scale planes and this is the only one that breaks the solder joints. I use Stay Brite solder, but it still breaks. Unfortunately, you can't use straight silver solder because the joint has to be soldered on the airframe to insure proper alignment. Using a torch would destroy the airframe. I'll try to lean out the engine to see if that makes a difference.
Ray
Maybe if needed, you can create a soldering jig like the one used on the Fokker DR1. This would be sacrificial, and then you can get the heat to those tabs? Another idea, might be to fabricate a solid plate that ties the front and rear Cabane struts together? Again, like the triplane. This would make that a solid structure able to withstand more stress.
