OK, your Futaba radio has a High Speed (HS) mode that it can operate at for channels 1 through 6. Check the set-up of the programming which is done at the receiver. How to do it is on page 26 of the manual. You do not want it in the HS mode with analog servos.
Also what type of battery pack are you using? By this, I mean which chemistry.
