14SG SBUS setup
Sanity check, please...
I have a DC3 that requires too many servos... I'm going to use S3071HV's X 11 for all the surfaces... it's a 14SG radio and the 7008 rcvr.
Q) I'm going to run a 2S lipo in each wing to power both the motors and the servos/rcvr. so each wing will have power going into a terminal to consolidate the 3 servos in each wing and power for the motor. Will I have issues with ignition noise with SBUS. The plan is to have one lead going to a terminal (Channel 8 on the rcvr) which will be distributed leads to tail, and both wings.
Q) I have electric retracts from ESM for this bird... can I plug them into the receiver directly for standard channel or do I have to buy a decoder?
Q) I read somewhere that someone actually daisy chained SBUS servos. Is there any concern of signal loss for soldered connections for SBUS?
thanks for your time!
