RCU Forums - View Single Post - DLE-85 85cc Gas Engine at troybuiltmodels.com
Old 05-20-2014 | 08:35 AM
  #144
Truckracer
My Feedback: (19)
Originally Posted by TonyBuilder
In my experience this engine/ carb floods easy. When I fuel up I have to clamp off the fuel line to the carb or fuel will drop out of the carb. Don't know what to say about your issues, normally all me engines have been hassle free.
TB
I've been following the DLE85 threads as I've considered getting one as a replacement engine for an old 33% plane hanging in my garage. Love the airplane but the engine is dated and needs replacement.
The engine flooding / starting problem you mention concerns me quite a bit. You are not the first to mention this and the DLE111 has also experienced the same problem. I don't know if the 111 and 85 share the same carb. No healthy Walbro or Walbro clone should leak gas during fueling. The only thing that could allow that is the metering needle. If it was leaking or if the pop off pressure was set way too low it could cause the problem. If this is the problem, I could certainly understand the engine being hard to start and continued flooding. Have you tested the pop off pressure on that carb?
