Originally Posted by
kneeboy
You know the funniest thing mario?
If you wouldnd of copied every little part of my design on your next microlight after my maiden went on youtube id never
have been sure enough to accuse you,
Id have had a feeling because of the sudden change from what you were working on for all them years but probably woukdnt of said anything.
you are that ignorant you copied almost every part down to the last details like the bend in the monopole
and am now disguising it and putting your own twist on it to hide this fact.
You used special effects on those few videos, so much that you couldnt really see much but could definately make out that it was remarkably similar to mine in almost every way!
You dont use these effects now that youve put your twist on it? Why is that??
1) You have said I copied your trike to the point of nauseam and you can't provide a detail single photo side by side of what it is that you claim I copied you.
2) Your Trike that you claim I copied you was making test flights barely in 2011 in the white and blue theme as the MIA Roto Trike was themed, that you were trying to make look, but bigger.
3) My MIA Roto-Trike, the one in the attached photo, again, in case you missed it.
I am giving you illustrative proof!
A) Flew perfect in the video I posted in 2009, also posted here.
B) Yours was barely flying 2 years later
You have the audacity to call my post 2009 trikes, which are based on the same design principles as my MIA Roto -Trike further with real detail elements that are not yours nor mine but
from real trike details, a copy of yours that you finally made it work later in 2011?
You made your rc trike work later in 2011 because you had a lot of reference already as in the attached photo, you don't want to admit this for some reason, even though the proof is clear.
I've giving you photos and dates and facts, you are simply throwing a lot of words.
Now you have been making your trike look more realistic, kudos to you, but the fact still remains that your rc trike did not fly until you changed it to have the same elements
as my Roto-Trike did back in 2009 and like I have shown it to you on many occasions and you well know it, has not been the only trike I did with the same elements. What more do you want?
You want me to give you credit for something that you borrowed from me, in the first place, to make yours work and ever since you built up a little momentum on your videos, now you think you can
go claiming rights not only for the design but also for elements that are also on real trikes.
Should everyone else stop putting cameras on their models, and not include figures poseable or robotic.
The only innovative twist on my RC microlights is the MIA Robo-Pilot that I perfected from the original 80's, all on the internet.
I think you should be thank full that you have had a guy like me post as much as I have posted and got you thinking in the right direction.
Try to comprehend what is posted and not just skim over the words. BTW you should check your grammar, before calling someone ignorant. "woukdnt" it is "would not have".
