Originally Posted by
MAUS45
Erik, the plate is not for a plastic hull it is for a metal Taigen hull to cover the hole if you remove the Taigen on/off and volume switches on the bottom of the new metal hulls. Here is a photo to show where it goes on the new Panther/JagdPanther metal hull. So would you consider carrying them now?
I'll look into it. The only tank it would be valid for us is the T34 atm. We don't carry the metal Panther/Jagdpanther hulls so it is limited use currently. I will keep this in mind though. Anything else while I'm at it?
