RCU Forums - View Single Post - OS 33GT Gasoline Engine for Pattern
Old 05-21-2014 | 04:28 PM
  #425
maustin's Avatar
maustin
My Feedback: (7)
Originally Posted by MTK
Looks like good progress. The 33 puts out about similar power to the YS175. It actually puts out more top end (which we never use) on the same props...but it's the mid range that will surprise you. You simply point the nose and add throttle for effortless verticals.
BTW- The early props I used during break in were 18.5 x 9.5 wide blade (I had one so I used it) and then the 19x11. I quickly (within a couple gallons) switched to the 20x10.5 PN apc and that has been a terrific match. Most recently my hand carved 20 1/4x 12 Narrow blade has been working very similar to the apc. Same noise footprint and similar thrust output per throttle setting. But this wood-carbon composite is only 77 grams, shaving 3 ounces from the nose.
Just completed a 22x10 Narrow Blade wood-carbon hybrid for the YS185. We will see how the 185 performs on that prop. We are looking for 7000 rpm which should be doable. I don't think the 33 will turn this much lumber so I won't even try it right now. Maybe later
Matt, I plan to start with an old APC 18.1 x 10. I have a Master Airscrew 18 x 8 wood job but don't think I'll try that one although it did run good on the bench. I noticed you have a Lipo 2500 mah for power. I was thinking of a Fromeco 2600 Lion.
Mike
