Just an update on my Terremoto. I installed the Ofna 17MM offsets on the wheels to eliminate the front wheel rub. Wow its great no rub and turns great! Looks a little tougher too. I would recommend the 8mm ones due to the screw in set pins but my local guy had a set if the 17s that were cheap so I just used cotter pins and it works perfect! I also perminantly locked the center diff with high temp gasket sealer. What a difference that makes! I tried diff locking oil and clay buy the are crappy. The sealer is perfect! I posted a short video on you tube so if you want to see check it out. Not sure if I can post a link here but its under redcat Terremoto custom. I added a wing and some braces , used rubber paint to cover the red, painted some parts orange and made my own metal body mounts cause the plastic ones break.
