Originally Posted by
jbrlty
Checked the battery. Seems to be OK. Unhooked each rotor separately and still kicked off the same way. Will not spin even one rotor at a time. As soon as the throttle is pushed forward the lights go off and it is dead.
Thanks anyway.
jbrity,
I do not know how you have checked the battery.
Suggest you connect a voltmeter on the battey and see what happens.
All your statements are pointing to a
so called 'brown out' when the voltage drops due to a possible short or high leakage.
Zor
