Originally Posted by
mort78
Hi LA Jetguy,
I read those posts that you are talking about, but my system still doesn't work like that. If I remove one of the RX's connected to the CB200, I get A1,A2,A3,A4 showing 0. But the system is still working. I don't understand why this is happening.
cheers,
Mort
Hi Mort,
tuned a CB200 with 2 Sat2 last week but still deedn't fly with it.
But with version 1.11 CB200 is working normally, except that you have the warning on TX 3.0 software. V1.2 should be out this week (as I read).
How did you connect your receivers to the CB, via PPM or EX, with one or 2 cables?
You cannot switch between dual path and teacher/student without modifying receiver modes:
In dual path you have two receivers operating in "normal" mode and bind them seperatly to the 2 TX modules
In teacher/student mode you have one receiver in "normal", and one receiver in "clone" mode , the two binded to one TX module (the other has to be binded to the student TX)
Please check
