Originally Posted by
mort78
Hi LA Jetguy,
I read those posts that you are talking about, but my system still doesn't work like that. If I remove one of the RX's connected to the CB200, I get A1,A2,A3,A4 showing 0. But the system is still working. I don't understand why this is happening.
cheers,
Mort
Mort,
As LA Jetguy mentions, others that are using V3.0 on their transmitter and V3.22 on their receivers, including myself, have this work correctly. Since you have previously said that you haven't upgraded your receivers to V3.22, I assume that is why you continue to see this issue. However, the system should continue to be safe to fly even though the transmitter and receiver firmware versions don't match. Is there a specific reason why you've chosen not to upgrade your receivers ?
