RCU Forums - View Single Post - JR R1221 RECEIVER PROBLEM
Old 05-27-2014 | 09:20 AM
invertmast's Avatar
invertmast
My Feedback: (23)
Originally Posted by affas
Thanks for all help!
What I did found out was that I did bind the model and got steady light. And if I turn the plane off and on again I get blinking rx and satellites. But if I turn off both plane and transmitter and do turn them on again I get steady light every time.
Strange or normal? Range check is done and it seems to be very good.
Turn on and fly the model?
normal.
If you turn off the model without cycling the transmitter power, the receiver picks back up the Tx on the original 2 frequencies that it was originally using and the LED's blink to give you an indication that the receiver had an intermittent power failure/disruption. Its described in the manual.
