Originally Posted by
wfield0455
Mort,
It seems extremely doubtful that your problem was caused by mismatched firmware versions between the transmitter and receivers. Can you please provide more information about your configuration? You mention using R7s connected to the central box. Assuming dual path mode, are they both configured for EX Bus communications, speed set to Auto? Is failsafe set to DISABLED in both of them? Failsafe should only be enabled in the Central Box.
I want to Emphasize this point above.. This is critical for the Satellite receivers above....
