RCU Forums - View Single Post - Viability of sharing a turbine between 2 models..
Old 05-28-2014 | 06:47 AM
wfield0455's Avatar
wfield0455
My Feedback: (7)
Good point, I hadn't thought about that. I suspect both the Jetcat and Kingtech store the run time in the ECU.
Also, when you order a turbine, are internal ECU values such as fuel pump voltage, etc, factory adjusted by test
running that turbine / ECU pair? If I order a new ECU will I be able to simply copy these values from one ECU to
the other or do they typically ship with default values?
