RCU Forums - View Single Post - Viability of sharing a turbine between 2 models..
Old 05-28-2014 | 09:03 AM
mr_matt's Avatar
mr_matt
My Feedback: (10)
The JetCat you have keeps the runtime inside the turbine not the ECU. If you swap with the proper electronics you don't need to do anything or adjust anything just swap the turbine.
EDIT: You DON'T have to keep the ECU and the turbine together. Just to clarify. This might be for a JetCat only, I don't know if anyone else is different.
