Hmmmm..nothing jumping out at me..
at what point did the model stop responding on the log? at the end?
See if you can get any data from the log files on the central box.. to see if it went into failsafe..
Looking at the data, all the signals took a dive at the same time.. so Im thinking failsafe... the quality numbers were fine up to that point ..
Is this an electric or a gasser? If a gasser, how is ignition powered? smoke pump?
sometimes when 4 channels take a dive at the same time, something is blocking the signals electronically..
How are the receivers oriented in the model?
Do you have the low voltage shutoff enabled in the Cbox by mistake?
