Hey Goose,
Ok... that's good to know we have found the problem.
Now some other questions I have for you:
1. Do you think there are any problems with the CB200 now? Is in, would the servo port be damaged at all. I used 2 servo ports on the CB (2x5.9V outputs from the Gemini).
2. Instead of combining the output leads from the Gemini, wouldn't it be better to solder 2 MPX connectors and use both CB power inputs?
Thanks again for your help. I'm glad the problem is solved.
Cheers,
Morten
