RCU Forums - View Single Post - Help Setting Fixed End Points with Jeti
Old 05-28-2014 | 07:42 PM
Dave Harmon
Originally Posted by KGSS28
Hey Jim why do the Jeti Spin 's have that little lag in motor restart comming out of brake ? I fly ATX SD 10 G and it is 3 clicks up for me. I don't notice it in the air but sometimes trying to use it landing I have to remember about the extra clicks .
Other than that I have always followed your lead in the setup and love these ESC's
Thanks Kirk
I made an idle up/idle down switch per Jim's info on another thread.
When in idle up...the prop spins slowly on the ground indicating that the brake is off.
With the brake off there is no dead spot or lag right off closed throttle....I turn off the brake (idle up) for landing and during the flight I select if I want the brake on or not with the switch.
As far as why there is a dead spot with the brake on....I don't know....but I thought I would jump in here and mention how I have it set up.
The OS 1100HV ESC does not have the lag with the brake on.....I have been flying the OS ESC for the past year and it is great....super easy to setup.
