Originally Posted by
KGSS28
Thanks Jim , I have done some creative THR curve stuff with a flight mode for landing that makes it pretty good. It will start at the fourth click at a slightly fast idle then I can come down one click to the some RPM as my idle . I also used the curve to take out a some above click 4 so it wont run out from out from under you if you need more in a head wind or something, all in about the bottom 1/4 or stick travel .
Turned out pretty smooth.
Is there a way to record or download the data the Mezon transmits without a Jeti Transmitter ?
You can record it with a Jetibox Profi on the ground and a Jeti receiver (that transmits the data to the Profi) in the plane. You can add other sensors in the plane, like GPS and record its data as well as the Mezon data. I believe the Mezon itself only records and stores a few highs/lows of the last flight.
Jim O
