RCU Forums - View Single Post - DLE-85 85cc Gas Engine at troybuiltmodels.com
Old 05-31-2014 | 01:28 PM
  #157
TonyBuilder's Avatar
TonyBuilder
Ok, so I mounted the engine to the test stand and tested the two ignitions for spark, I could not get it to run the other day, (at the end of my patients). The one thing I did not check was the pick up, so I put the new one on and wha-la spark on both ignition modules, that's good news. So this must have been the root of all the issues. My arm is still a mess from last week so we pulled the club starter out, it is a big heavy duty on a marine 12v battery. It started right up, we tuned it and it ran great. With the Bowman ring it was idling like a watch, 1500rpm, and peaking at 6300rpm on the factory settings, 1.5 turns out. The low end was a bit rich so we leaned it and it ran even better.
I started it about 4 times with the starter and I could kill the engine and start it with one flip, did that about 4x. So I think my issues are past with the new pick up, the Bowman ring and the new carb. I will use the club starter for now, my arm is shot.
This is is a big relief and sends new energy to the current build.
TB
