RCU Forums - View Single Post - Saito 150 problems
Old 10-05-2003 | 07:26 AM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: Saito 150 problems
The very early 150's had more compression than the later ones. But they generally ran OK if you didn't use 30% nitro fuel in them.
These engines will either have an "A" or else nothing stamped on top of the right mounting lug. Engines with letters farther down the alphabet stamped on the right lug are not the high compression ones.
You problem sounds more like a air leak or fuel problem and not anything resulting from the high compression. The high compression engines gave more trouble when you were trying to start them. They would back fire and throw the prop on acceleration too.
Good luck,
Jim
