RCU Forums - View Single Post - CG check
Thread: CG check
Old 06-01-2014 | 01:41 PM
serious power
Originally Posted by Jetdesign
It doesn't matter what you put in for the stab, the MAC is for the wing and doesn't change. The one linked by OhD looks pretty good. I clicked the 'back' button on the bottom of the page and found the reasoning behind the tool. It makes sense and is inline with the article I linked above:
Basically the 25% MAC is about where the "Aerodynamic Center" of the wing is - a position on the wing in which the CG will generate no pitch forces (moments) regardless of the attitude of the wing.
This goes with the thought that changes in CG should not have an impact on elevator trim. If you change your CG and it affects your elevator trim, you are outside of the 'zone' - either too far forward or too far back. This also goes with the idea that the stab should not be generating lift for the airplane. The wing flies the plane, the stab guides the plane.
Hi Joe,
The tail stats,, and efficiency that one enters do change the CG result it produces.
However all I was saying is that most people refer to their cg as a % of MAC or an actual distance. That tool requires you to enter a static margin figure to work.
So using your own data you have to use 25% for the static margin (which is overly forward/stable) to get the 167mm result.
167 is 33% of MAC which isn't exactly a forward setting.
I'm not saying the tool is wrong, it just looks from a perspective not normally referred to. It could add to the confusion that all this jargon sometimes causes.
Brian
