RCU Forums - View Single Post - CG check
Thread: CG check
Old 06-02-2014 | 08:13 AM
  #36
MTK
Originally Posted by serious power
Hi Jim,
Yes , was just trying to stay away from stuff that clouds the issue.
On re-reading some of the posts I think that maybe MAC is being confused with AC !!??
As a matter of interest what % of MAC did you end up with and then using that tool what static margin needs to be specified so as to derive that ?
Brian
When setting up my designs, I use one of the popular calculation tools on-line to get the ball park cg figure. It's a reasonable starting point. For example, for a typical (for me) wing area, stab area, moment arm (ac to ac) and 15% static margin, the tool often returns the "IDEAL" CG AT 32% mac. This cg location will typically push to belly in knife edge flight. I have to trim quite a bit more to minimize the push. I get close to zero mix but find my planes can use a couple % mix so I add it and go play. I don't sweat the small stuff...2-6% is very small actual movement, so it's no biggie in my book.
