Originally Posted by
kmrcjets
hi dave what is the biggest jetcat turbine that will fit into the xcalibur
ken
Hi Ken,
diameter of Jetcat P80se, P90RXi, P140RX, and P180RX all have a diameter of 112 mm
The P100 has a diameter of 97mm. The P60 has a diameter of 82.5mm
Kingtech turbines diameter K 60G is 82 mm. K80G and K100G are 95.25mm.
K140G, K170G and K180G are all 114.3mm
I think it's important that before you jump into purchasing this Jet you do your homework and be sure that the turbine you have or going to buy will fit and is suited for this jet. This rule obviously goes to any Jet or prop airplane you buy, weather it is turbine , turbo prop, electric, gas, nitro
, etc.
Hope this helps with your project.
