RCU Forums - View Single Post - Need help tuning
Old 06-04-2014 | 09:59 PM
gerryndennis
Sounds like you are getting there,
I agree, I would have thought you can use less ether for a larger engine, but you can experiment with that later. 30% should be fine.
DII isn't absolutely required but it does make things a lot nicer. Starting is improved, you can run lower compression, and settings are less critical. I use 1% and that makes a noticeable difference, 1.5% should be fine. Amsoil is the way to go.
I'm intrigued by the 'silicon O ring', is this just a ring sliced of the end of a silicon tube? What diameter? How much is it compressed by? Do you cut a square cross section or a bit longer like a sleeve?
Well done so far,
Dave H
BTW well done on the 'redneck' prop load.
