Originally Posted by
Dave Wave
I am building a quadcopter....I am using a 5000 mah battery that has 8awg leads on it. The expected draw from the copter does not need wire this large. 12awg Is what I am using to run power to the point it is distributed to the motors.
I tried stripping the 8awg and wrapping the 12 around the stub, then soldering. Not only is this hard due to the mass, but the result is not very pretty.
Is there a better way to do this? I want a soild/simple connection that will not fail.
Thanks!
-Dave
Dave
Need a 25W or bigger iron 1st
then both wires should be stranded if you have heat shrink tubing put on wire next
then push both together into one wire all the little wires will touch each other. enter trine
if you have flux then flux or just solder the wires together.
then push heatshrink over ..heat an done.
its the best joint ever made
rich
