Originally Posted by
jescut
Hi Guys
I think that mine is not working properly. It is not working all the time. Do I made something wrong? I follow the instructions but nothing. Can anyone tell me how to set it up in case I made something wrong?
I am not sure if you have the same problem i have on my F16 but when i switch on the rx the valve light is off. This is a protection so s to save the gears from retracting if you forget the switch in the ''up'' position. The is obvious only on my f16 where you can see the doors don't have air in the cylinder as they touch the gears.On my f18 this problem is not noticeable.According to the manufacturer you need to retract extend once and the valve is energized or you switch on the transmitter while you have the retract switch on the 'up' position then cycle it to down and then switch on the receiver.
