Originally Posted by
ziggy12345
OK I just read the manual again and it said that it is essential that the ignition plug is located at the 12 o'clock position. I assumed the ignition plug was where you plugged in the ignition fuel line. The one with IGNITION stamped on it. The electrical plug for ignition was at the 6 O'clock position. I think this might be the problem.
It says the engine might be damaged. I'll need to check with Behotec to see if its OK again before I start it.
Cheers
The clocking is correct.
Starter fuel line at 12 o'clock, which brings the MPX plug close to 6 o'clock.
Sorry if I confused you with my explanations. I actually updated the manual on this matter to make it less confusing.
