RCU Forums - View Single Post - NIMH charging to over the rated capacity?
Old 06-07-2014 | 06:58 AM
wherermykeys
Default NIMH charging to over the rated capacity?
Hi everyone. First post here. Just getting back into the RC world after a 10 year hiatus. I recently picked up a Stampede 4x4 and had a battery question. The Traxxas battery that came with it is rated at 3000MAH. I had my charger set at a max of 3000MAH with a delta peak of 9mv/c and it's been charging to 3000MAH every time. I figured it can't actually be charging to exactly 3000MAH every single time so I thought maybe the battery could take a bit more and to let the charger decide when it's full. I set it to a max of 3200MAH at 8mv/c and it still put 3200 into it. I wound up with 10.802V. Can this be right? Am I overcharging the pack? Should I try setting the sensitivity lower?
