Shockwave problem
I have a shockwave that I broke in the way the manual said to, it run great for a day after I tuned it. We flipped it once and hit a small bush no damage but when it shut off it would not start until it completly cooled. Now we can run it until it gets hot and it slows down and will barely make it back to you. Let it cool start it up again and same thing happens whether you top off the fuel or not, but when it does that if I pick it up for a min or to and let it run in the air then set it back down it runs great for another min or two. What could be the cause of this problem? I did change to a hot plug when it all started could this be the problem?
