Here are some pics from the first chippy. The design is solid, but the linkages were flawed and failed.
The ruder will be linked like this but with the improved carbon fiber tube and pined arms.
Theruder will be the same but soldered steel for the pull-pull arm.
The elevator is a totally new design over this failed setup. One offset 4-40 in a carbon fiber tube will be used.
TB
