For all the years you were successfully running the engine, which propeller were you using? You mention that you "upped" the prop to a 12 x 7. Did you change your needle settings? Did you change your fuel? Exhaust system? How is it cowled? Is the fuel system free-flowing with no leaks? You need to make sure everything is correct before suspecting the engine, itself.
