update. i got the idle steady and the engine doesnt heat up like it used to. I turned the low needle rich. also, the mid is a little better, but still stalls out. I learned that if i adjust the high speed needle lean the mid throttle stabilizes quite well, but its too lean at wide open throttle. im attaching a video take a look and tell me what you think. Thanks.
http://youtu.be/hldxRTYLWwU
