RCU Forums - View Single Post - Viability of sharing a turbine between 2 models..
Old 06-10-2014 | 10:49 AM
  #53
essyou35
Cool, thanks for the correction. Curious, what jet engines do you/did you work on?
Also can you explain what your connection to Kingtech is in your signature? Never seen that before.
Thanks!
Originally Posted by gunradd
You count starts (engine cycles) because the start is where the engine gets most of its wear. Most of the parts on the engine are life limited to both Engine Cycles and Hours.
