Paul60, you don't need to reverse the gear servos at all.
Just ensure that the servo horns are orientated in the same direction at a given switch setting (either pointing towards or away from the frame connection point), and the gear will work with the right sized servo horn regardless of if it turns either anti or just clockwise (there's enough clearance on mine at least).
