RCU Forums - View Single Post - Need help tuning
Old 06-10-2014 | 06:42 PM
  #33
flybyjohn
Default video
I put 1.5% ACB into the fuel and it did run a lot better. Still 700 rpm below the glow on the same prop setup but it seemed to run pretty smooth. I measured in mass ounces because I didn't have anything small enough to measure .12 oz because I only had 8 oz of fuel left. I used my reloading scale and converted the oz to grains. Any way, I made a video of the engine running and me trying to tune it. Please let me know if you think I got it right or if I am doing something wrong. It is a long boring video, I start it two times and fiddle with the tuning both times. With the hillbilly prop load I have on it, it maxes out at 9000 rpm and idled at 1800 rpm. It transitions well. I am still using the 30% ether, 25% castor, and the remainder kero/heptane and 1.5% ACB. Heres the video if your board. I think I need a new main bearing as I get a little noise with both the glow and diesel at idle.
https://www.youtube.com/watch?v=xqGc_zIiQko&feature=youtu.be
